Newbie
Message 1 of 5
Problems with bitcoin wallet
Hi All,
I just recently got Infinity 1 installed, I get a good 5.4mb download and a strong 1.2mb upload (tested via uploading to a french server / vps), however I wish to host a bitcoin node on my network, however I am stuck because the wallet does not send any traffic out, I know BT throttle P2P on the line (ive noticed on torrents like linux) but I didnt think it was this bad, is there something I can do about this as I really want to help the network out and host a node.
Any help would be appreciated !
Hect0r
4 REPLIES 4
Expert
Message 2 of 5
Re: Problems with bitcoin wallet
I assume that you followed the setup instructions and forwarded the appropriate port.
Quote from one site: "It’s critical that you forward port 8333 on your router to the IP address of the computer that is running your node".
More info here:
https://medium.com/@lopp/how-to-set-up-a-bitcoin-full-node-2dd1c09763d3
And here:
https://bitcoin.org/en/full-node
Loads more info, just Google for it.  Don't forget to adjust QOS settings or you could impact your browsing etc.
Newbie
Message 3 of 5
Yes I have port forwarded 8333 to the node ipaddress, its uploading data, but not alot.
Expert
Message 4 of 5
If, as you say, you only have 1.2mbps upload it's not a lot to begin with, equates to about 150 kilobytes/sec.  So not a lot.  The router may also be applying QOS to the connection so that your browsing etc is not affected too much.
Message 5 of 5
BT do not throttle P2P services and have not done for a few years now
