Turtles
Newbie
Message 1 of 3
Problems with specific games.
So this problem seems to be isolated to only a few games on the Xbox One for me, the main one being Grand Theft Auto 5, I have contacted Rockstars support and they have come up empty and have said it must be my ISP. I have tried using a static IP, portforwarding both Xbox Live and GTA ports, I have used DMZ, uPnP as well as making sure my NAT is open all to no avail. The game is near unplayable and I have found little online that has helped. Does anyone know why this is happening and if their is a fix?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Problems with specific games.
Try running a download at the same time as playing the game.
If not, I'll try again 🙂
Turtles
Newbie
Message 3 of 3
Does not appear to have helped.
