Kahn1
Message 1 of 12
Quality of service feature on bt hubs
How is this still not a thing? The network congestion is insane when someone is watching netflix and im trying to play a game, i shouldn't have to buy a nighthawk router to fix this, get on it bt YOU should be providing it not a 3rd party
11 REPLIES 11
Keith_Beddoe
Message 2 of 12
Re: Quality of service feature on bt hubs
BT supply a basic router for free, to provide you with a connection, and make it easy for them to support.
If you want anything with better features, then you have to buy your own. You do not need to buy a Netgear Nighthawk, the TP Link TD-W9970 (£40)  has QOS and bandwidth controls to control users.
https://www.tp-link.com/uk/products/details/cat-15_TD-W9970.html#specifications
Kahn1
Message 3 of 12
supply a basic router for free? i got a smart hub that i pay out the azz for, not free and not a basic router
imjolly
Message 4 of 12
you pay for broadband and phone not the hub  the hub is free and only if you do not complete your agreed fixed term contract will you need to pay for the hub
Kahn1
Message 5 of 12
Ya and i had to pay so not free, bt don't come knocking on my door every router generation with a free improved device
imjolly
Message 6 of 12
you chose to buy the hub but you were supplied with a hub when you joined BT  The days of a free hub everytime you renew your contract have gone  You can still with a bit of negotiation get a new hub when you come to renew your contract but they are not offered
This is no different to most companies now.   I renewed my SKY contract but was not offered a free SKY Q box
Kahn1
Message 7 of 12
Im sure i seen a Quality of service feature on another common home hub from another provider...or maybe not my memory is a little fuzzy but i would be surprised if none of the big providers offered the feature, point being if even 1 of them have it bt can do it too, how difficult can it be to tell the hub to prioritize something
Keith_Beddoe
Message 8 of 12
If BT supplied an advanced router, then the amount of extra support staff that would be needed to deal with all the different possible configurations, would cost BT a fortune.
As it is, the home hub can always be reset to a known state, by a factory reset, making it easy to support. There is nothing special about the home hubs, unless of course you believe all the advertising hype.
Kahn1
Message 9 of 12
Re: Quality of service feature on bt hubsi
Quality of service is not a complex feature, it could be patched into current hubs if they really wanted to
imjolly
Message 10 of 12
I think @Keith_Beddoe post suggests not as simple as you think and not to mention the extra staff required to answer all the queries that would arise from it
you never know maybe some future hub will have the facility
