Bobwootton
Message 1 of 4
Question about a symbol in WholeHome app
Wondering that this symbol means? Can’t an explanation online...  thanks.
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: Question about a symbol in WholeHome app
Pure Guess; is the device connected to that disc configured for static ip?
RachIngram
Message 3 of 4
Hi there,
I had the same question so did some experimenting and it is just showing you what disc you are connected to - as in, the device you are using to look at the app from! So I turned my bedroom disc off and then the purple person moved to the livingroom disc and my device had also changed to that disc!
Hope that helps 👍🏻
Bobwootton
Message 4 of 4
Thanks, that’s the conclusion I had reached as well.
