Message 1 of 2
Random SAAF - is this normal?
I noticed a few days ago my port forwards seemed to disappear.  I eventually tracked it down to this event on 20th March in the morning.  I was nowhere near the router (BT Hub) at the time.
There is a random DoS port scan (I have redacted my own public IP in the log below) followed by a SAAF restart (which obviously wiped my port forwards)
09:19:09, 20 Mar. PPP LCP Receive Configuration ACK
09:19:08, 20 Mar. PPP LCP Send Configuration ACK
09:19:08, 20 Mar. PPP LCP Receive Configuration Request
09:19:08, 20 Mar. PPP LCP Send Configuration Request
09:19:05, 20 Mar. PPP: Received PADS
09:19:05, 20 Mar. PPP: Sending PADR
09:19:05, 20 Mar. PPP: Received PADO
09:19:05, 20 Mar. PPP: Sending PADI
09:19:00, 20 Mar. PPP: Starting PPP daemon
09:18:57, 20 Mar. WAN Auto-sensing detected port Ethernet WAN
09:18:56, 20 Mar. Booting firmware v0.38.00.10147-BT (Fri Oct 14 23:39:03 2022)
09:18:53, 20 Mar. System start Button press (SAAF)
09:18:52, 20 Mar. System up
09:18:33, 20 Mar. WAN Auto-sensing last connection port: Ethernet WAN
09:17:46, 20 Mar. System restart, reason: SAAF
09:17:45, 20 Mar. TLS 0 Close
09:17:45, 20 Mar. SIP 60da1e06 SEND 200 NOTIFY
09:17:45, 20 Mar. SIP 60da1e06 RECV NOTIFY
09:17:45, 20 Mar. SIP 60da1e06 RECV 200 SUBSCRIBE
09:17:45, 20 Mar. SIP 60da1e06 SEND SUBSCRIBE
09:17:45, 20 Mar. SIP De-registrations
09:17:45, 20 Mar. DoS(UDP Loopback): IN=ppp0 OUT= MAC= src=128.232.21.75 DST=81.xxx.xxx.xxx LEN=28 TOS=0x00 PREC=0x00 TTL=240 ID=54321 PROTO=UDP SPT=33967 DPT=19 LEN=8 MARK=0x8000000
1 REPLY 1
Message 2 of 2
Re: Random SAAF - is this normal?
