Message 1 of 7
Re: 900mpbs new setup dissapointed
Why don't you just use your current router in modem mode and look at a mesh setup?
Think I seen a 3 pack of Deco M5s for around £140 recently.
6 REPLIES 6
Message 2 of 7
Why would you need a modem on an FTTP connection? The ONT is the modem.
Message 3 of 7
So can I plug a mesh system directing in to the ONT or does that not have to go through the router for authentication purposes first?
Message 4 of 7
You are confusing your terminology, you referred to using the router as a modem, which you don't need as the ONT is the modem. You will need a router of some description, either a mesh system that incorporates a router (as many do) or a standalone router and pure wifi mesh without router capability.
Message 5 of 7
Ah right.
So using my current setup as an example.
I use a deco mesh system in access point mode, hard wired in to my BT home hub which is in modem mode.
Once FTTP is installed I can directly connect my deco mesh (in router mode) to the ONT without the need for a router?
Does the ONT (as a modem) have any sort of firewall protection built in or would this need to be part of the mesh setup if connecting directly as a router?
Message 6 of 7
I've split this off from the thread you posted on as it is not relevant to that thread.
First of all, BT hubs don't have a modem only mode, all you have (presumably) done is to turn off wifi and DHCP.
If the Deco mesh has a router mode, then yes, you can connect it directly to the ONT without a hub. You will need to enter the generic PPPoE credentials of
Username bthomehub@btbroadband.com
Password BT
There is no firewall in the ONT
Message 7 of 7
Thanks for all your advice.
