Chrissparks001
Message 1 of 12
Re: At wit's end, slow broadband and rubbish router
Enjoyed fantastic service up until early October. Fault was deemed to be my wireless connection.
I had changed nothing but the wireless connection issue seems to coincide with the BT marketing of their wireless connectivity hubs in every room programme.
This coincides with BT offering to extend my contract for 18 months instead of 12. Now trapped in contract but can buy myself out for £300+.
BTs solution is that my entire family connect all devices to the router using hard wire
OR
We buy their connectivity hubs.- How lucky are we that this solution coincides with this problem!
Thankfully BT had a commercial solution just in time.
Gosh but they are clever. 🙂
11 REPLIES 11
imjolly
Message 2 of 12
Are you on old adsl or on a fibre connection
can you post stats from your router. If hh6 then advanced settings then technical log information. If hh5 then troubleshooting then helpdesk
enter your phone number and post results remember delete number.   https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Chrissparks001
Message 3 of 12
Im on fibre.
I have been informed that a lot of my devices which used to be in range a month ago are now not. As a result the system is configuered to limit the download speeds to these devices to 2.4 M Bt / second.
They have me by the preverbials.
I paid to have the wireless upgrade as I need to work.
Very clever if not deviously sharp marketting is how my overly suspicious mind has been left. Not exactly the right frame of mind on which to build a long lasting relationship!
Apologies I can waste any more time on this.
Some great deals available with other suppliers though.
licquorice
Message 4 of 12
I think you are confusing the 2 frequency bands used for wifi 2.4Ghz and 5Ghz and speed. It doesn't mean your wifi speed is 2.4Mb/s, it just means your devices are using the 2.4Ghz band.
Chrissparks001
Message 5 of 12
Service is still massively degraded from a month ago. The wi fi range has massively deteriorated to less than 2 metres or so. Now that isn't something we have done. There has been a technical change to the nature or quality of the broadband service BT have chosen to provide.
The only way to get workable downloads is if we all connect to the router with wired connections. The problem is, there are only 4 sockets on the router and mobile devices do not have sockets!
The guarantee of 30 M B/sec is only for wired connections! Who in this day and age only uses wired connections?
  Bit like guranteeing that your matchlock pistol will fire 3 times in every 10!
Anyway I may have found the solution.
You simply pay up!
I will let you know when the new hubs and boosters are installed along with another upgraded Router. (2nd Router in a week)!
Thanks anyway.
imjolly
Message 6 of 12
presumably you did switch off smart setup and selected wireless channels manually rather than leave on automatic
licquorice
Message 7 of 12
@Chrissparks001 wrote:
No there hasn't, either the hub has gone faulty or your environment has changed causing wireless interference.
It is impossible to guarantee wifi performance and no ISP does so, there are too many variables to consider.
You simply pay up!
Thanks anyway.
Keith_Beddoe
Message 8 of 12
Its more likely that the internal wireless module, or its connection to the internal aerial has gone faulty. This has been reported before on this forum, and its typical of very cheap mass produced ISP routers. Its quite rare for commercial branded routers, probably due to better quality control.
Its also possible that you have a strong interfering wireless signal from another nearby device like a wireless video sender. These do not show up as a wireless network, but can blot out up to three adjacent wireless channels.
Usually changing the wireless channel on the home hub can help.
Chrissparks001
Message 9 of 12
They have sent a new hub and its the same problem.
Do you think its two faulty hubs?
Cant think of any environmental changes at all.
Wireless connectivity is good up to 2 to 3 metres away but after that abysmal.
You say 'It is impossible to guarantee wifi performance and no ISP does so, there are too many variables to consider.'
This is exactly what the call centre have said but it doesnt alter the fact that it was good a month ago and now is unusable, guarantee or not.
Carlusha
Recognised Expert
Message 10 of 12
Have you tried Keith's suggestion of :
It worked for me a couple of years ago when a large family moved in next door. I cannot remember how I pulled it off but it was a relief to be back up to speed. We now have 9  wifi connections on the go without any issues.
