Message 1 of 3
Re: Eero 6 mesh
Just had a Nokia ONT installed and purchased the eero 6 router, I was hoping to directly use the eero 6 with the ONT modem, can anyone confirm if this is a suitable setup?
eero app fails to connect to internet. Unless there is a specific vlan tag for the Nokia ONT (already attempted 101 and 10 from other posts in hope it would work)
I was under the impression the eero 6 supports FTTP.Therefore I could ditch our vodaphone router and directly connect to the ONT
2 REPLIES 2
Message 2 of 3
Re: Eero 6 mesh
Why are you posting on a BT retail forum when your ISP is Vodafone?
You need to ask on their forum.
Message 3 of 3
Re: Eero 6 mesh
