Message 11 of 17
Re: Extending wifi signal of hh5 using a hh3
I currently use a TP-Link TD-W9980, very happy with it.
profixit
Message 12 of 17
Thanks, can they be linked/AP extension.
Message 13 of 17
Yes, if you really want to. If you just want wireless access points, buy wireless access points. The only reason to use hubs is if you have a spare one lying around therefore nil cost involved. If you are buying equipment, buy the right thing rather than bodge something together.
jet11x
Message 14 of 17
Thank you - clearly written.  Worked first time for me (using hub 3 as secondary to hub 6).
mcoombsuk
Newbie
Message 15 of 17
Really helpful, thank you. Just one question - I've recently followed these instructions again for setting up my new Hub 6 and using my old Hub 5 as the extender, but despite being connected without any issues the orange broadband light continues to flash on the Hub 5. Have a missed something in the setup or is this just a feature of the Hub 5 which can't be turned off when used this way?
prinknash
Expert
Message 16 of 17
@mcoombsuk.  It's a 'feature', I'm afraid. You could try covering the light up. The alternative is to use something that does wireless access point properly (I use an old Asus router) and doesn't flash.
p
Message 17 of 17
Yes, it is because the Hub has no DSL input.
