velominati
Newbie
Message 1 of 3
Re: HH5 and Google Chromecast
I just got my HH5 - up until now I've been using an old O2 hub (my Chromecast worked fine with the O2 hub).
I've done the following:
  • renamed 2.5GHz band
  • Changed to channel 1 (based on monitoring the channel usage)
  • turned off UPnP
  • turned off parental control
  • turned off smart setup
  • factory reset the chromecast device
I've run out of things to turn off or change but the Chromecast still doesn't work. Has anyone managed to consistently solve these problems yet?
2 REPLIES 2
velominati
Newbie
Message 2 of 3
Here is a description of the symptoms that I get:
  • I use the CC app to config the device
  • onscreen I get to the "connecting" message
  • app fails to find the device on the network
  • I can now cast a tab to the device
  • after 3 minutes the casting freezes and I can no longer cast an app
  • onscreen message changes to "set me up"
(I guess the 3 minutes is the CC device connection timeout)
Like I said above I have tried the following:
  • turned off UPnP
Jonkarra
Expert
Message 3 of 3
I've got a HH5 with default settings for wireless. I've not turned anything off or unsynced 2.4 abd 5GHz and it works perfectly had both for over a year and apart from having to replace the googlecast because it was making an annoying noise I've had no problems.
Tags (1)
