Turnip
Message 1 of 3
Re: Homehub 2 admin login
I am havibg trouble connecting my Home Hub 2 with my IPad. I have reset the hub to the default settings and used the original admin password to no avail. A while ago bt changed the password but I have lost it. Surely resetting the hub to the default settings should avoid this problem ? Ant idea as to what else I can try ?
2 REPLIES 2
Message 2 of 3
To connect to the Homehub you have to use the wireless passkey found on the homehub label not the admin password.
Message 3 of 3
it is case sensitive so check ipad not capitalising first letter
