2ndmouse
Message 1 of 2
Re: Homehub 4 slower than Homehub 2
My infinity 2 was installed 11th Sep  I also have really slow wifi in the last week or so. @john46, can you elaborate on your answer - I don't understand it as  it is.
ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ ˁ˚ᴥ˚ˀ
I started out with nothing and I still got most of it left
1 REPLY 1
Message 2 of 2
I moved your post to start your own subject so replies will be specific to you
you can try downloading inssider3 (istumbler if MAC) and then run it. This will show the broadcasting networks round about you and their channels including your own. If you then enter your router and change your wireless channel to a free or less congested channel.
to enter hub enter 192.168.1.254 into your browser then go to wireless and you can change from automatic to manual and then select the channel you have decided by using inssider
