JNation
Newbie
Message 11 of 17
Re: Hub 6 wireless now unuseable
Just done that thanks. Do you know if we need to disable on the hub as well. Not sure what going to do when it affects wifi again
smf22
Recognised Expert
Message 12 of 17
I don't believe there is an option to disable on the Home Hub 6.
Regards
Toon1000
Newbie
Message 13 of 17
Thanks guys. Using a static IP as described above solved my problem of the iPad not connecting to the internet with HH6.
dnp
Message 14 of 17
Unfortunately, had to go back to manual IP settings today to get a wireless connection, even with IPV6 unchecked, as the default gateway had 'disappeared'.
smf22
Recognised Expert
Message 15 of 17
@dnp Are you able to post the version of Windows you're running (type winver from the command line), and also the version of firmware on the Home Hub 6?
Regards
dnp
Message 16 of 17
Hub version SG4B100021EC
Using Win 10 1607 build 14393.105
I see now that although I am getting internet access, I am not properly connecting to the network and cannot 'see' other computers or network printers, just  media devices and my NAS drives
dnp
Message 17 of 17
I have gone back to manual IPV4 settings, IPV6 disabled and everythign working as it should. Apart from one machine on the network still using DHCP with no problems (this one does not yet have the Win 10 anniversary update).
