Banquo
Newbie
Message 1 of 7
Re: Problems with BT Smart Hub and Powerline adapters (TP Link AV1300)
Similar- I got a new smarthub and my TP-Link (albeit old) PLA's stopped working; I can 'see' the network, but can't use it to access anything as it won't connect. Have tried everything, re-boots etc etc even using the TP-Link Utility. It worked fine with my previous Sky Hub ...both networks over FTTC. Any help please? Its annoying to have far worse wi-fi connectivity having switched.
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Hi @Banquo and welcome to the community.
Thanks for posting. I've moved your post to the Home setup board as the thread you posted on was quite old and this board might be more suitable to getting an answer. Have you managed to resolve this yet? Are the lights all correct on the PLA's? Have you tried changing cables etc?
Cheers
David
V_Meldrew
Recognised Expert
Message 3 of 7
Make sure your PLA's are set to obtain an ip addess by DHCP or, if you prefer them to be set for static ip, make sure the gateway address is set to 192.168.1.245 (the default Sky gateway is 192.168.0.1), the ip address is set for the correct subnet (192.168.1.xxx) and there are no ip clashes
Message 4 of 7
That should be 192.168.1.254 not 245
V_Meldrew
Recognised Expert
Message 5 of 7
Sorry, finger trouble
TimCurtis
Recognised Expert
Message 6 of 7
@V_Meldrew
Since when do PLAs use IP Addresses? Apart from pairing them there's no configuration required.
Message 7 of 7
They should just be transparent, but certainly the BT ones have an IP address for management purposes.
