Message 1 of 3
Re: Slow connection on Smart Hub 2
Hi, I have wifi issue since a month.
With wired connection I have no issues.
Since a month the Hub restart itself frequency. Sometimes in every 10 mins, sometimes 2 -3 times a day...
After restarting the download speed drop down drastically.  5-6 Mbps or more... Sometimes less than 1Mbps.
If I reset the HUB (switch off till 10 sec), the download speed increase to 30-35 Mbps but 5-10 mins later the HUB restrart itself and the download speed drop down again... This mean the wifi is totally unusable.
Here is my Broadband Availability Checker:
And here is my technical log info:
Product name:
BT Hub 6A
Serial number:
+084319+NQ72275343
Firmware version:
SG4B1000E079
Firmware updated:
20-May-2022
Board version:
1.0
Gui version:
1.126.0
DSL uptime:
0 Days, 0 Hours 9 Minutes 42 Seconds
Data rate:
15.31 Mbps / 24.92 Mbps
Maximum data rate:
15533 / 35217
Noise margin:
6.1 dB / 9.8 dB
Line attenuation:
50.4 dB
Signal attenuation:
36.2 dB / 50.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
109 MB Uploaded / 1 GB Downloaded
Broadband username:
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-5P7R
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-5P7R
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
84:A1:D1:B8:BD:5D
Software variant:
Boot loader:
7.33.1
Till long time (more than 5 years) I had not any wifi issues at all.
Any suggestion?
Need I a new HUB?
2 REPLIES 2
Message 2 of 3
Today morning I also tested the speed on wired connection:
Here is the result:
Message 3 of 3
provided you don't have digital voice and you check your phone line for a dial tone  then dial 17070 option 2 it should be silent and best with corded phone   if no dial tone or your hear line noise then report phone fault to 150 if phone works or 03301234150 from mobile
