Message 1 of 2
Re: Smart Hub 2 and Whole Home Discs
Hello,
I connect the first "white" disc to the router, they pair successfully but once the ethernet cable is disconnected then the red light appears...……….I do not understand the solution given as nothing has changed ???
Ant further help would be appreciated
1 REPLY 1
Message 2 of 2
@Caspian606 wrote:
Hello,
You need to have one white disk connected to the home hub all of the time, as the smart hub 2 will only work with the black BT Complete Wifi system, and act as the first node.
