Cbcarolyn
Message 21 of 22
Re: Smart Plug Connection
It works on the WiFi extender which has its own name and password and is 2.4 only
zippy_
Message 22 of 22
Looking like you will have to use the extender, I have no other suggestions for you except maybe change whatever app you are using and try again. I have spent hours sometimes with these plugs, some connected OK others refused.
I now use the Tenda WiFi extenders and everything works and connects as it should anywhere in the property.
Good luck, again please keep everyone updated with your journey.
