Message 1 of 5
Re: Smart hub 2 ssid renaming
My microwave is interfering with TV so I want to point the TV to 5gHz
4 REPLIES 4
Message 2 of 5
It is your TV that decides whether to connect at 2.4or 5ghz. As you cannot split the 2.4/5ghz with sh2 you really need A router where you give separate  SSID to 2.4 and 5ghz networks
Message 3 of 5
Unless it is right next to your TV if your microwave is causing interference I would get it checked. It could be faulty and is leaking the microwave radiation.
Message 4 of 5
I seem to remember that you couldn't have separate SSIDs for the 2.4 and 5Ghz for the (not so) Smart hub 2. Contract was up for renewal for me, so shifted to EE before forced to and got a new wifi 7 hub. Configured two SSIDs and all good. Cloned my BT hub SSID on the EE  and all devices connected. Third party hubs will work on BT Broadband... I connected a Zyxel and connected ( eventually 🤣)
Message 5 of 5
That was pointed out in message 2 posted by @imjolly
