Message 1 of 5
Re: Wifi Disc Ordering
Hi,
I'm having difficulty finding out how to order additional discs – my broadband speed is under 10mbps download – can anyone help please?
Matt
4 REPLIES 4
Message 2 of 5
@MattyWW
Welcome to this user forum.
Could you please try this --> online troubleshooter <-- as you may able to order another disc that way yourself.
Message 3 of 5
Thanks Keith – just going through that now. Fingers crossed.
Message 4 of 5
If it is your broadband speed that is slow rather than your WiFi speed, another disc won't help.
Can you post the stats from your hub please?
Message 5 of 5
The connection to the hub is fine – it's the wifi which is slow.
Have got an additional disc on order.
Thanks for your help!
