enfield250
Message 1 of 3
Re-cycling old hub
Hello!
I am getting confused, I have just installed my new smart hub.
I have packaged up the old hub and dsl unit.
The label on the bag says to peel off the bar code label on the box, but there isn't one.
the address label on the bag is BT returns, BT DF.
No where to put a bar code, do I actually need the barcode and if so where do I get one from.
Or do I just take the green bag to the post office.
Cheers
2 REPLIES 2
Message 2 of 3
Re: Re-cycling old hub
just take it to post office
TimSmedley
Message 3 of 3
Hi I found my green bag actually went into out local post box comfortably, if that's easier...
\tim
