unclehefty
Message 1 of 2
Re: iPad Air, iPhone 5 and Apple TV wifi drops out Home Hub 5
I'm not certain if this is the right place but I recently (last week) installed my new HomeHub5 and tried to link my Apple TV to it.  ATV does not recognise the new HomeHub5 but it does recognise an Apple Timecapsule . Is there a conflict between HH5 and ATV?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Hi unclehefty,
Thanks for posting. Have you had a look at this thread?
https://community.bt.com/t5/Other-Broadband-Queries/iPad-Air-iPhone-5-and-Apple-TV-wifi-drops-out-Ho...
Let us know if that helps.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
