dangerous97
Message 1 of 3
Re-locate home hub away from master socket.
Hello.
Late last year I moved house, BT 5c master socket in the most inconvenient place
My HH5 is plugged into that master adsl port.
Is it possible for me to run a new cable to a new slave telephone socket in a more convenient place in the house to re-locate my router?
How would I plug the router into the socket as the slave (I assume) wouldn’t have an adsl socket. Do I need an old school micro-filter to plug the hub into that?
Thanks in advance.
2 REPLIES 2
licquorice
Message 2 of 3
Re: Re-locate home hub away from master socket.
You just need to run a cw1308 cable from the data extension terminals of the nte5c to an RJ11 socket. Only 2 wires are needed. If you need telephony as well as the hub at the extension, fit an extension phone socket instead of RJ11 and use a filter.
imjolly
Message 3 of 3
This may help
https://www.openreach.co.uk/orpg/home/helpandsupport/how-toguides/howtoguides/downloads/NTE5C_Instru...
