Calumh
Message 1 of 8
Re: low internet speed on 5g compared to 2.4g wifi
Can anybody recommend a third party router which will successfully run Bt tv (IPTV) and normal internet services through the same port?
i have all of my tv and games console related kit, including the bt uhd tv box, running from a switch from one port on the HH5.
With my archer c9 I could get IPTV working on the bt uhd box but that would break internet access for the other devices connected to the same switch.
If if I could I would run another cable but I can’t as this is in a recent extension which does not have a crawl space, and has oak flooring nailed on to the plywood base...
Thanks!
Calum
7 REPLIES 7
Message 2 of 8
I think the only way to do it would be with a managed switch.
Calumh
Message 3 of 8
Excellent, thanks!  Had no idea that a managed or smart switch would work.  Found this article that addresses my issue from searching with the info you provided.
http://www.tp-link.com/us/faq-1125.html
Now need to pick a decent 8 port managed or smart switch that my lack of networking talent can cope with!
calum
Calumh
Message 4 of 8
Somebody marked this as solved but the question answered was not the original poster’s question?
Message 5 of 8
No, but I split this off on to its own thread as it was a different question to the original problem. It is only this thread that is solved not the original.
One of the mods marked it as solved.
Calumh
Message 6 of 8
Ok, excellent. I just clicked the link and was concerned I’d gazumped the OP.  Thanks again.
calum
ps - managed switch should arrive tomorrow.
Calumh
Message 7 of 8
Managed switch here, set up and uhd tv working!  Thanks again!
Message 8 of 8
Glad you got it working, thanks for the update.
