bellbrie
Message 1 of 3
Real-Debrid Speed Very Slow
Last coupe of days I have seen my Real-Debrid speed, on Inifinity, drop to about 150Kbps.
Speedtest shows that I am still gettign about 80Mbps download spped, so its not the connection.
Is RD being throttled or is there someother issue?
Anyone else having problems?
Thanks.
2 REPLIES 2
Message 2 of 3
Re: Real-Debrid Speed Very Slow
BT don't throttle.
b_bez
Message 3 of 3
The issue is at Debrids side.  Down to bad routing or overloaded servers.  Problem still going on Sept 2018
