dan44762000
Message 1 of 10
Recommend me a new Router please
Ok so the general consensus amongst people i have asked is the Home Hub is a pile of garbage,so i want to buy myself a better router,one with more functions and generally better
So which one should i get , i would prefer as little haslte as possible setting it up to work with BT
I,m on infinity 2 and do watch Bt Sport through the set top box , so it would need to work with that also
Many thanks
Daniel
9 REPLIES 9
Burmey
Message 2 of 10
Re: Recommend me a new Router please
Watching this thread. I'm so fed up with the orange (looks orange to me) light coming on and wails of "who's turned the wifi off " from the family with "smart" hub 6 in the last 3 months. Husband can't use wifi calling for work when he's working at home anymore and he's going to,have to go back to working in Isle of Man as it's unsustainable when he keeps getting cut off. Was great for about 6 months but has been awful since January.
licquorice
Message 3 of 10
Only you can decide what features and functionality are important to you, have a look at the specs and decide. Just ensure it is a VDSL modem/router if you want a one box solution. Virtually all of them will have a quick setup option that will require only user name bthomehub@btbroadband.com and a password of BT to be entered when prompted in order to set it up.
Its like asking somebody to recommend a car.
dan44762000
Message 4 of 10
Thanks for the reply and password/username info , i could disagree more about comparing asking for a recommendation of a router to that of a car though, you are being very pedantic about it .
A simple question about some router recommendations does not remotely compare to that of asking which car to get.
imjolly
Message 5 of 10
sorry I disagree  you need to decide what you want from your new router/modem  do you want dual band, do you want QOS, do you want to spend £35 or £200 etc
many use the cheap tplink 9970 on vdsl and they say it works well others prefer more facilities and buy dearer models
licquorice
Message 6 of 10
Of course it does,  I have no idea of your requirements and everybody will have their favourite car/router. If you stick to the well known brands they are all pretty much the same. The main cause of price variation is wifi speed. If you have no need of a high speed wifi LAN, the governing speed of your internet connection will be your broadband. I could recommend the TP Link VR600 or VR900 but if you only require a very basic device, the TP Link TD-W9970 would suffice.
Technonerd
Message 7 of 10
Agreed with the recommendations above. Or, you could go with one of the Billion range, especially if you want a router with a good BDCM chipset and line monitoring capabilities.
alistair94
Message 8 of 10
Speaking from experience, after years of frustration with various BT Homehubs including several replacement HH6, I bought a TP Link Archer VR900. Since then I haven't had a single issue, no disconnections, fast wifi, easy to set up extenders, Sky + , Amazon Echos and a network drive. Everything has worked seamlessly.
Technonerd
Message 9 of 10
Yeah, the TP Link's have great WiFi, just a shame that they have very little line stats.
cooperman
Message 10 of 10
I agree with the TP-Link reccomendations. Have had a V1 version of the Archer VR900 for some time now and it has been rock solid with excellent wifi to numerous gadgets connected. Just remember to keep your BT Hub as BT wont help you with a non BT Hub connected if you get line problems.
