maxr198
Newbie
Message 1 of 2
Recommendations On VDSL Routers
Looking for any recommendations for VDSL routers that work well with BT.
Open to all suggestions, I'm currently a Superfast fibre customer.
Edit:
The only requirement I have thinking about it is that I would like the option to pipe all my traffic over a VPN so a OpenVPN feature would be ideal.
Thanks!
1 REPLY 1
Message 2 of 2
Re: Recommendations On VDSL Routers
There are plenty of them, but you need to make sure that they will work with multicast, just in case you ever want to use BT Youview.
Two for starters    TP Link W9970   £40       TP Link AC1200  £65
These both support multicast.
I am sure you will get other suggestions.
For one  VPN setup https://www.tp-link.com/ae/faq-2195.html
Or https://www.tp-link.com/us/faq-1237.html
Or https://www.tp-link.com/us/faq-1239.html
Not sure if that is what you mean?
