Message 1 of 5
Recommended modems for FTTC?
Hello! Are there any other modems compatible with BT apart from the Vigor 130? Looking for a replacement because I am having several issues and I believe it might be the modem and not my router or the line itself.
4 REPLIES 4
Message 2 of 5
Re: Recommended modems for FTTC?
Huawei HG612, oldie but still a goodie. Plenty on eBay, don't pay extra for an unlocked one. It is unnecessary and trivial to accomplish in any case if required.
Message 3 of 5
Hi @licquorice do you know if the normal bt smart hub 2 psu works with the huawei modem?Bt smart hub 2 plug
Message 4 of 5
Sorry, I don't know but I very much doubt it as the SH2 PSU is renowned as having a completely non standard plug size.
Message 5 of 5
@Anthony813 - Plusnet Hub Two's support Bridge mode (effectively turning them into a 'dumb' modem) and the PSU connector from a Smart Hub 2 would fit it.
