ukbirdflu
Message 1 of 5
Recycle Home Hub 4
I just upgraded to Infinity and received a Smart Hub, all the packaging were thrown away before I opened the recycling bag, this requires the return address label with a bar code from the Smart Hub packaging, which has been thrown away already. If I bring the bag to the post office, will thy accept it without my return label?
4 REPLIES 4
Message 2 of 5
Re: Recycle Home Hub 4
just keep the hub or dispose of it your self you do not need to return it
Message 3 of 5
I wouldn't be in a rush to get rid of it if I were you!! You might be glad of it. Smiley Wink
ukbirdflu
Message 4 of 5
You sounds like you are doubting the reliability of the Smart Hub, if that is the case I will hand on to HH4, but can HH4 work with Infinity? Bearing in mind I have only 1 socket and have to use the filter to split the connection into Hub and phone.
Message 5 of 5
The HH4 won't work with Infinity stand alone, you would need a separate Openreach modem as well.
I doubt the reliability of all Home Hubs.
