hyattjon
Message 1 of 7
Refusal to replace faulty Homehub after just 9 months?
I'm completely and utterly frustrated with BT's insane customer non-care.
As I am out of contract with my Infinity 2, last January I paid to upgrade a (broken) 3 year old homehub3 to a homehub5. Now, 9 months on, various problems have resulted in the BT guys saying this homehub is also faulty.
The indian call centre lady says I can get a free replacement if I re-contract.
Great I thought, so I ring 150 at 09:30 this morning (Tuesday). 2 hours later I finally get given a "special customer options" number and ring it.
They say yes, you just need to re-contract and you can have a free replacement homehub. Further into the process he sees I have BT Basic, the reduced price line rental contract for disabled customers like me who are claiming DLA.
Oh, he says, I cannot get you a free replacement homehub unless you re-contract at full £15.99 line rental and take free weekend calls.
Some time later I realise that if I do that I'm paying an extra £120 over a year for a £50 homehub. I try to insist he re-contracts me on my current package and then I should still get a free replacement homehub, he gets bad tempered and just keeps saying " I have offered you all I have to offer" and refuses to even bump me up to a supervisor.
I just got so stressed I told him to leave it and ended 2 and a half hours of frustration.
Apart from the fact that I am on BTBasic because I am autistic and rely on benefits to survive, I don't get out of the house very much nowadays so Broadband is my lifeline to the outside world.
Utterly scandalous, callous and uncaring IMHO. Whatever happened to a guarantee against faults anyway?
Can anybody here explain this absurdity, or even possibly help me?
6 REPLIES 6
vofsanity2
Recognised Expert
Message 2 of 7
Re: Refusal to replace faulty Homehub after just 9 months?
The Hub should be replaced under warranty provided you have a statement from BT that it is faulty. There is no need for you to re-contract.
The moderators should be able to help you with this.
hyattjon
Message 3 of 7
Thank you. Then I will await a moderator.
Moderator
Moderator
Message 4 of 7
Hyattjon,
I'll be able to arrange a replacement hub. Please send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
hyattjon
Message 5 of 7
Thank you.
hyattjon
Message 6 of 7
Thanks go to robbie, my problems should soon be solved I hope.
I'm away at the moment at a respite care centre, I should be back on Wednesday and I'm hoping to find a promised HomeHub replacement on my doormat!
I'll update then.
Moderator
Moderator
Message 7 of 7
Hi hyattjon,
I'm glad I could help you get a replacement Hub 5 sent out.
Your case has been closed off now but feel free to come back on to the forum and create a thread if you need help or have any questions about your BT services in future.
All the best,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
