alisoncymru
Newbie
Message 1 of 6
Removing BT Smart Hub prompt
A cousin gave me their laptop this afternoon, which I am trying to sort out using my BT wifi network.  My cousin is a BT customer too.
When I go to certain websites, e.g. BBC, I get redirected to the welcome to the BT Smart SetUp.
I understaned Smart SetUP isn't in use anymore and the laptop has been conveted to Windows 10 (not by me).
So how do I turn this thing off?  Note: I don't have this issue with any other device that's connected to my wifi, including another laptop.
Thanks.
5 REPLIES 5
Message 2 of 6
Re: Removing BT Smart Hub prompt
Welcome to this user forum.
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
alisoncymru
Newbie
Message 3 of 6
Thanks.  I had already come across that page and I'm not getting much luck.  That's not the interface I have (I have Home Hub 5).  I have gone through all the settings (signed in as admin) to try and identify smart hub settings and I can't find anything.
Message 4 of 6
Certainly the HH type 5A is exactly as shown in the link for the HH4/5.
Message 5 of 6
Your subject line said smart hub, which is the BT Home hub 6.
On the home hub 5, its on this screen. Just select "No"
alisoncymru
Newbie
Message 6 of 6
Got it, thank you so much.
