Liam_
Expert
Message 11 of 12
Re: Removing Portforwarding Rule - Hub6
Having to jump through all these hoops suggests the Hub is seriously broken.
A proper router with UPnP enabled will let you create and delete any port forward rules.  If the device application is  no longer in use the port forward should automatically disappear.
jrpmedia
Message 12 of 12
You're right, the BT HH 6 Router is an over-priced piece of rubbish... for all the reasons above alone.
