Message 1 of 2
Removing hub and cables
I have BT cable and hub through my lounge and hallway, can I just remove it or does BT have to remove it?
1 REPLY 1
Message 2 of 2
Re: Removing hub and cables
Any cables etc in your house are your responsability so you can move them if you want to.
Do not throw the hub out if you were/are a BT customer as BT will want it back.
