HHGTTG
Expert
Message 1 of 5
Renaming Network devices.
Hi. When I examine my Network on my Home hub 3, I have one or two not named just labelled 'unknown' followed by the MAC address. Can I I safely replace the unknown with a suitable Device name and then press 'Save'? Would this upset the connection next time the Device (Internet Radio) is used?
4 REPLIES 4
Message 2 of 5
Re: Renaming Network devices.
Yeah you can rename the devices, its just a pretty picture of your network nothing more.
HHGTTG
Expert
Message 3 of 5
Thanks very much.
HHGTTG
Expert
Message 4 of 5
Just revisiting this topic, I started, I also have another question.
When I interrogate my Home Hub's UI I can see various devices connected or currently dormant. My Brennan B2 shows up named udhcp followed by the MAC address. Is it OK to replace the udhcp part with 'BrennanB2' for easy identification? I did that for my Internet Radio following advice here.
Is there any significance in the 'udhcp' rather than having 'unknown' in the device's identification?
Message 5 of 5
As I said before, the whole thing is just a pretty picture and has no real purpose, not sure why you need to keep looking at it. But yes, anything that is manually changeable can be changed and will have no impact on the operation of the hub/device.
