Jez39
Message 1 of 9
Renaming devices
I have recently replaced my Smart Hub 2 (due to old one dropping out frequently) and now cannot rename my devices in the BT App. I cannot see where the option is. The Help page says go to “Manage on-line screen time” but this option doesn’t seem to be anywhere in the App. I have been able to rename them using the Hub’s web page but this doesn’t seem to feed into the information accessed by the BT App   Why is this?  I used to be able to use the App to rename devices but now can’t.
8 REPLIES 8
Message 2 of 9
Re: Renaming devices
In the MYBT app go to
your wifi network
control wifi access
select the device you want to rename
then next to name 'edit'
change name
Jez39
Message 3 of 9
Only get “Manage your wi-Fi settings” as an option from the “Your wi-Fi network” link which takes you to your Hub and Discs and then the connected devices but without an Edit option. I am sure with my old SH2 there was another option.
Message 4 of 9
When you get to connected devices did you then select a device  as edit only appears after you select a device
Jez39
Message 5 of 9
Having selected the device I don’t get an Edit option
Message 6 of 9
When I select your wifi network I then see my hub and my disc and setup new disc.  Below that I have control wifi access for your devices. If I select that then I can see all my wifi devices and selecting a device I then get option to edit name
my app version is 8.8.5
Jez39
Message 7 of 9
My App is 8.8.1 and the IOS App State has this version as the current one!
Message 8 of 9
I am using android not IOS but facilities should be same
just tried on my iPad on 881 and works just like my android and as I previously described
Jez39
Message 9 of 9
  • Guess there must be some reason for the difference. I don’t get “control WiFi access for your devices” but “manage your WiFi settings” that then doesn’t allow you to change device names, only the network name.
