Newbie
Message 1 of 3
Renting house currently has Virgin Media
House I am going to rent currently has Virgin Media no BT line so the engineer has to call. Does anyone know if the engineer will be able to use the same entry points as Virgin Media or will they need to make new entry points
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Renting house currently has Virgin Media
Openreach would not be able to any virgin cables or sockets. I suspect they could use a similar cable route from where it terminates on the outside of your premises.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 3
Thy will most likely make new entry points
