say-what
Message 1 of 11
Replacement for Homehub - as advised by faults team
Hey,
Sadly from moving in there have been massive issues over the last year.
My contact is up soon and would prefer not to move. Sadly the faults team have not helped and will not look an errors. They only check if the line is ok then and there
Anyway I have alot of connection issues with it dropping out alot. My last day off (my birthday) it happened 12 times. Amongst some other issues which points to the hub being an potential issue (but that stuff is for another day)
BT have suggested using a  different router. Having a look I can see that some do not like being used with BT TV (sports, etc). Sadly BT will not say what might have better odds of it working. An intresting sugestion to make and then not advise which direction is best
Anyway got any Modem & router sugestions for fibre? I can see from the forums that Netgear is to be avoided
I also saw that the openreach modem might be a good shout. I have seen people use it online, but BT helpline says it will not work.
I am at the end of my contract, is it best to stick with them or go to Zen?
Any help/advice would be really appreciated!
10 REPLIES 10
imjolly
Message 2 of 11
Re: Replacement for Homehub - as advised by faults team
a popular replacement is the tplink 9980 about £35
you could post your router stats here and see if the forum members can help you improve your existing connection
are you currently using the test socket with a filter to see if that improves stability by eliminating your internal wiring
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
say-what
Message 3 of 11
Hey,
Thanks, appreicate that item for the potential shopping list. I don't mind paying more, but would rather a recommendation, so that helps alot!!
I have found one for about £50 with postage, that seems ok at **TPLINK TD-W9980B :: WIFI-N Gigabit router, dual band VDSL2/ADSL2+**
I have a few logs over times as they asked me to keep them - but won't take them to look
Here is the log for the WAN section of the event log
Please give me a nudge and I can get other logs too
I have logs from issues with netflix stuttering - packets getting blocked and wierd changes to the firewall.
Even when the device is not in the building it kept opening and closing connections for port fowarding.
I am not expecting fixes for the other parts, just thought I would mention incase it was helpful to people with better knoledge when looking at the log below
I have not tried the engenire port from when they changes the socket a month or two ago. Thanks for the reminder, I will sort that out now
1
03:11:19, 14 Feb. (300647.600000) WAN operating mode is VDSL
03:11:19, 14 Feb. (300647.600000) Last WAN operating mode was VDSL
03:11:17, 14 Feb. (300645.810000) PPP IPCP Receive Configuration ACK
03:11:17, 14 Feb. (300645.800000) PPP IPCP Send Configuration Request
03:11:17, 14 Feb. (300645.790000) PPP IPCP Receive Configuration NAK
03:11:17, 14 Feb. (300645.660000) PPP IPCP Send Configuration ACK
03:11:17, 14 Feb. (300645.660000) PPP IPCP Receive Configuration Request
03:11:16, 14 Feb. (300644.850000) PPP IPCP Send Configuration Request
03:11:14, 14 Feb. (300643.270000) PPPoE is up -​ Down Rate=59995Kbps, Up Rate=17847Kbps; SNR Margin Down=8.5dB, Up=6.2dB
03:11:14, 14 Feb. (300643.260000) CHAP authentication successful
03:11:14, 14 Feb. (300643.190000) CHAP Receive Challenge
03:11:14, 14 Feb. (300643.190000) Starting CHAP authentication with peer
03:11:14, 14 Feb. (300643.190000) PPP LCP Receive Configuration ACK
03:11:14, 14 Feb. (300643.170000) PPP LCP Send Configuration Request
03:11:14, 14 Feb. (300643.170000) PPP LCP Receive Configuration Reject
03:11:14, 14 Feb. (300643.160000) PPP LCP Send Configuration ACK
03:11:14, 14 Feb. (300643.160000) PPP LCP Receive Configuration Request
03:11:14, 14 Feb. (300643.160000) PPP LCP Send Configuration Request
03:10:43, 14 Feb. (300611.520000) PPP LCP Send Termination Request [PPPoE PADT received]
03:10:43, 14 Feb. (300611.460000) PPPoE is down after 1042 minutes uptime [Disconnected]
09:48:21, 13 Feb. (238072.690000) WAN operating mode is VDSL
09:48:21, 13 Feb. (238072.690000) Last WAN operating mode was VDSL
09:48:19, 13 Feb. (238070.760000) PPP IPCP Receive Configuration ACK
09:48:19, 13 Feb. (238070.640000) PPP IPCP Send Configuration Request
09:48:19, 13 Feb. (238070.630000) PPP IPCP Receive Configuration NAK
09:48:19, 13 Feb. (238070.630000) PPP IPCP Send Configuration ACK
09:48:19, 13 Feb. (238070.630000) PPP IPCP Receive Configuration Request
09:48:19, 13 Feb. (238070.380000) PPP IPCP Send Configuration Request
09:48:17, 13 Feb. (238068.630000) PPPoE is up -​ Down Rate=59995Kbps, Up Rate=17847Kbps; SNR Margin Down=8.4dB, Up=6.1dB
09:48:17, 13 Feb. (238068.610000) CHAP authentication successful
09:48:17, 13 Feb. (238068.550000) CHAP Receive Challenge
09:48:17, 13 Feb. (238068.550000) Starting CHAP authentication with peer
09:48:17, 13 Feb. (238068.550000) PPP LCP Receive Configuration ACK
09:48:17, 13 Feb. (238068.540000) PPP LCP Send Configuration Request
09:48:17, 13 Feb. (238068.540000) PPP LCP Receive Configuration Reject
09:48:17, 13 Feb. (238068.530000) PPP LCP Send Configuration ACK
09:48:17, 13 Feb. (238068.530000) PPP LCP Receive Configuration Request
09:48:17, 13 Feb. (238068.520000) PPP LCP Send Configuration Request
09:48:02, 13 Feb. (238053.950000) PTM over DSL is up
09:47:22, 13 Feb. (238014.000000) PTM over DSL is down after 14 minutes uptime
09:47:22, 13 Feb. (238013.990000) PPPoE is down after 14 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
09:47:18, 13 Feb. (238009.190000) PPP LCP Send Termination Request [User request]
09:32:47, 13 Feb. (237138.710000) WAN operating mode is VDSL
09:32:47, 13 Feb. (237138.710000) Last WAN operating mode was VDSL
09:32:45, 13 Feb. (237136.710000) PPP IPCP Receive Configuration ACK
09:32:45, 13 Feb. (237136.540000) PPP IPCP Send Configuration Request
09:32:45, 13 Feb. (237136.530000) PPP IPCP Receive Configuration NAK
09:32:45, 13 Feb. (237136.440000) PPP IPCP Send Configuration ACK
09:32:45, 13 Feb. (237136.440000) PPP IPCP Receive Configuration Request
09:32:45, 13 Feb. (237136.150000) PPP IPCP Send Configuration Request
09:32:43, 13 Feb. (237134.320000) PPPoE is up -​ Down Rate=42814Kbps, Up Rate=12459Kbps; SNR Margin Down=5.5dB, Up=5.8dB
09:32:43, 13 Feb. (237134.310000) CHAP authentication successful
09:32:43, 13 Feb. (237134.140000) CHAP Receive Challenge
09:32:43, 13 Feb. (237134.060000) Starting CHAP authentication with peer
09:32:43, 13 Feb. (237134.060000) PPP LCP Receive Configuration ACK
09:32:42, 13 Feb. (237133.890000) PPP LCP Send Configuration Request
09:32:42, 13 Feb. (237133.890000) PPP LCP Receive Configuration Reject
09:32:42, 13 Feb. (237133.800000) PPP LCP Send Configuration ACK
09:32:42, 13 Feb. (237133.800000) PPP LCP Receive Configuration Request
09:32:42, 13 Feb. (237133.710000) PPP LCP Send Configuration Request
09:32:27, 13 Feb. (237118.880000) PTM over DSL is up
09:31:49, 13 Feb. (237080.690000) PTM over DSL is down after 692 minutes uptime
09:31:49, 13 Feb. (237080.690000) PPPoE is down after 434 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
09:31:44, 13 Feb. (237075.900000) PPP LCP Send Termination Request [User request]
02:17:09, 13 Feb. (211000.120000) WAN operating mode is VDSL
02:17:09, 13 Feb. (211000.120000) Last WAN operating mode was VDSL
02:17:07, 13 Feb. (210998.280000) PPP IPCP Receive Configuration ACK
02:17:07, 13 Feb. (210998.270000) PPP IPCP Send Configuration Request
02:17:07, 13 Feb. (210998.270000) PPP IPCP Receive Configuration NAK
02:17:07, 13 Feb. (210998.260000) PPP IPCP Send Configuration ACK
02:17:07, 13 Feb. (210998.260000) PPP IPCP Receive Configuration Request
02:17:06, 13 Feb. (210997.690000) PPP IPCP Send Configuration Request
02:17:05, 13 Feb. (210996.040000) PPPoE is up -​ Down Rate=41780Kbps, Up Rate=13844Kbps; SNR Margin Down=5.7dB, Up=6.0dB
02:17:04, 13 Feb. (210996.030000) CHAP authentication successful
02:17:04, 13 Feb. (210995.960000) CHAP Receive Challenge
02:17:04, 13 Feb. (210995.960000) Starting CHAP authentication with peer
02:17:04, 13 Feb. (210995.960000) PPP LCP Receive Configuration ACK
02:17:04, 13 Feb. (210995.950000) PPP LCP Send Configuration Request
02:17:04, 13 Feb. (210995.950000) PPP LCP Receive Configuration Reject
02:17:04, 13 Feb. (210995.950000) PPP LCP Send Configuration ACK
02:17:04, 13 Feb. (210995.950000) PPP LCP Receive Configuration Request
02:17:04, 13 Feb. (210995.940000) PPP LCP Send Configuration Request
02:16:33, 13 Feb. (210964.250000) PPP LCP Send Termination Request [PPPoE PADT received]
02:16:33, 13 Feb. (210964.240000) PPPoE is down after 257 minutes uptime [Disconnected]
21:59:24, 12 Feb. (195535.360000) WAN operating mode is VDSL
21:59:24, 12 Feb. (195535.350000) Last WAN operating mode was VDSL
21:59:22, 12 Feb. (195533.610000) PPP IPCP Receive Configuration ACK
21:59:22, 12 Feb. (195533.600000) PPP IPCP Send Configuration Request
21:59:22, 12 Feb. (195533.590000) PPP IPCP Receive Configuration NAK
21:59:22, 12 Feb. (195533.590000) PPP IPCP Send Configuration ACK
21:59:22, 12 Feb. (195533.590000) PPP IPCP Receive Configuration Request
21:59:22, 12 Feb. (195533.500000) PPP IPCP Send Configuration Request
21:59:20, 12 Feb. (195531.970000) PPPoE is up -​ Down Rate=41780Kbps, Up Rate=13844Kbps; SNR Margin Down=5.8dB, Up=6.0dB
21:59:20, 12 Feb. (195531.950000) CHAP authentication successful
21:59:20, 12 Feb. (195531.870000) CHAP Receive Challenge
21:59:20, 12 Feb. (195531.870000) Starting CHAP authentication with peer
21:59:20, 12 Feb. (195531.870000) PPP LCP Receive Configuration ACK
21:59:20, 12 Feb. (195531.860000) PPP LCP Send Configuration Request
21:59:20, 12 Feb. (195531.860000) PPP LCP Receive Configuration Reject
21:59:20, 12 Feb. (195531.860000) PPP LCP Send Configuration ACK
21:59:20, 12 Feb. (195531.850000) PPP LCP Receive Configuration Request
21:59:20, 12 Feb. (195531.850000) PPP LCP Send Configuration Request
21:59:06, 12 Feb. (195517.680000) PTM over DSL is up
21:58:27, 12 Feb. (195478.730000) PTM over DSL is down after 0 minutes uptime
21:58:09, 12 Feb. (195460.260000) PTM over DSL is up
21:57:29, 12 Feb. (195420.900000) PTM over DSL is down after 1 minutes uptime
21:57:29, 12 Feb. (195420.890000) PPPoE is down after 0 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
21:57:25, 12 Feb. (195416.250000) PPP LCP Send Termination Request [User request]
21:56:34, 12 Feb. (195365.120000) WAN operating mode is VDSL
21:56:34, 12 Feb. (195365.120000) Last WAN operating mode was VDSL
21:56:32, 12 Feb. (195363.140000) PPP IPCP Receive Configuration ACK
21:56:32, 12 Feb. (195363.140000) PPP IPCP Send Configuration Request
21:56:32, 12 Feb. (195363.130000) PPP IPCP Receive Configuration NAK
21:56:32, 12 Feb. (195363.130000) PPP IPCP Send Configuration ACK
21:56:32, 12 Feb. (195363.120000) PPP IPCP Receive Configuration Request
21:56:32, 12 Feb. (195363.120000) PPP IPCP Send Configuration Request
21:56:30, 12 Feb. (195361.350000) PPPoE is up -​ Down Rate=60694Kbps, Up Rate=13825Kbps; SNR Margin Down=5.7dB, Up=9.4dB
21:56:30, 12 Feb. (195361.340000) CHAP authentication successful
21:56:30, 12 Feb. (195361.270000) CHAP Receive Challenge
21:56:30, 12 Feb. (195361.270000) Starting CHAP authentication with peer
21:56:30, 12 Feb. (195361.270000) PPP LCP Receive Configuration ACK
21:56:30, 12 Feb. (195361.270000) PPP LCP Send Configuration Request
21:56:30, 12 Feb. (195361.260000) PPP LCP Receive Configuration Reject
21:56:30, 12 Feb. (195361.260000) PPP LCP Send Configuration ACK
21:56:30, 12 Feb. (195361.260000) PPP LCP Receive Configuration Request
21:56:30, 12 Feb. (195361.260000) PPP LCP Send Configuration Request
21:56:15, 12 Feb. (195346.630000) PTM over DSL is up
21:55:38, 12 Feb. (195309.380000) PTM over DSL is down after 0 minutes uptime
21:55:23, 12 Feb. (195294.230000) PTM over DSL is up
21:53:24, 12 Feb. (195175.310000) PTM over DSL is down after 424 minutes uptime
21:53:24, 12 Feb. (195175.310000) PPPoE is down after 423 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
21:53:19, 12 Feb. (195170.460000) PPP LCP Send Termination Request [User request]
14:49:48, 12 Feb. (169761.000000) WAN operating mode is VDSL
14:49:48, 12 Feb. (169761.000000) Last WAN operating mode was VDSL
14:49:46, 12 Feb. (169759.210000) PPP IPCP Receive Configuration ACK
14:49:46, 12 Feb. (169759.200000) PPP IPCP Send Configuration Request
14:49:46, 12 Feb. (169759.190000) PPP IPCP Receive Configuration NAK
14:49:46, 12 Feb. (169759.190000) PPP IPCP Send Configuration ACK
14:49:46, 12 Feb. (169759.190000) PPP IPCP Receive Configuration Request
14:49:46, 12 Feb. (169759.180000) PPP IPCP Send Configuration Request
14:49:44, 12 Feb. (169757.590000) PPPoE is up -​ Down Rate=65846Kbps, Up Rate=19491Kbps; SNR Margin Down=4.5dB, Up=5.2dB
14:49:44, 12 Feb. (169757.580000) CHAP authentication successful
14:49:44, 12 Feb. (169757.520000) CHAP Receive Challenge
14:49:44, 12 Feb. (169757.520000) Starting CHAP authentication with peer
14:49:44, 12 Feb. (169757.520000) PPP LCP Receive Configuration ACK
14:49:44, 12 Feb. (169757.510000) PPP LCP Send Configuration Request
14:49:44, 12 Feb. (169757.510000) PPP LCP Receive Configuration Reject
14:49:44, 12 Feb. (169757.510000) PPP LCP Send Configuration ACK
14:49:44, 12 Feb. (169757.500000) PPP LCP Receive Configuration Request
14:49:44, 12 Feb. (169757.500000) PPP LCP Send Configuration Request
14:48:53, 12 Feb. (169706.050000) PTM over DSL is up
14:48:12, 12 Feb. (169665.340000) PTM over DSL is down after 414 minutes uptime
14:48:12, 12 Feb. (169665.330000) PPPoE is down after 413 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
14:48:08, 12 Feb. (169660.850000) PPP LCP Send Termination Request [User request]
07:54:21, 12 Feb. (144834.060000) WAN operating mode is VDSL
07:54:21, 12 Feb. (144834.060000) Last WAN operating mode was VDSL
07:54:19, 12 Feb. (144832.400000) PPP IPCP Receive Configuration ACK
07:54:19, 12 Feb. (144832.390000) PPP IPCP Send Configuration Request
07:54:19, 12 Feb. (144832.380000) PPP IPCP Receive Configuration NAK
07:54:19, 12 Feb. (144832.380000) PPP IPCP Send Configuration ACK
07:54:19, 12 Feb. (144832.380000) PPP IPCP Receive Configuration Request
07:54:19, 12 Feb. (144832.370000) PPP IPCP Send Configuration Request
07:54:18, 12 Feb. (144830.890000) PPPoE is up -​ Down Rate=68004Kbps, Up Rate=19984Kbps; SNR Margin Down=6.0dB, Up=6.0dB
07:54:18, 12 Feb. (144830.870000) CHAP authentication successful
07:54:18, 12 Feb. (144830.810000) CHAP Receive Challenge
07:54:18, 12 Feb. (144830.800000) Starting CHAP authentication with peer
07:54:18, 12 Feb. (144830.800000) PPP LCP Receive Configuration ACK
07:54:18, 12 Feb. (144830.800000) PPP LCP Send Configuration Request
07:54:18, 12 Feb. (144830.790000) PPP LCP Receive Configuration Reject
07:54:18, 12 Feb. (144830.790000) PPP LCP Send Configuration ACK
07:54:18, 12 Feb. (144830.790000) PPP LCP Receive Configuration Request
07:54:18, 12 Feb. (144830.790000) PPP LCP Send Configuration Request
07:53:27, 12 Feb. (144779.820000) PTM over DSL is up
07:52:48, 12 Feb. (144741.010000) PTM over DSL is down after 1 minutes uptime
07:52:48, 12 Feb. (144741.000000) PPPoE is down after 0 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
07:52:43, 12 Feb. (144736.440000) PPP LCP Send Termination Request [User request]
07:51:53, 12 Feb. (144685.900000) WAN operating mode is VDSL
07:51:53, 12 Feb. (144685.900000) Last WAN operating mode was VDSL
07:51:51, 12 Feb. (144684.070000) PPP IPCP Receive Configuration ACK
07:51:51, 12 Feb. (144684.070000) PPP IPCP Send Configuration Request
07:51:51, 12 Feb. (144684.060000) PPP IPCP Receive Configuration NAK
07:51:51, 12 Feb. (144684.050000) PPP IPCP Send Configuration ACK
07:51:51, 12 Feb. (144684.050000) PPP IPCP Receive Configuration Request
07:51:51, 12 Feb. (144684.040000) PPP IPCP Send Configuration Request
07:51:49, 12 Feb. (144682.390000) PPPoE is up -​ Down Rate=35948Kbps, Up Rate=12306Kbps; SNR Margin Down=5.5dB, Up=6.0dB
07:51:49, 12 Feb. (144682.380000) CHAP authentication successful
07:51:49, 12 Feb. (144682.330000) CHAP Receive Challenge
07:51:49, 12 Feb. (144682.320000) Starting CHAP authentication with peer
07:51:49, 12 Feb. (144682.320000) PPP LCP Receive Configuration ACK
07:51:49, 12 Feb. (144682.320000) PPP LCP Send Configuration Request
07:51:49, 12 Feb. (144682.320000) PPP LCP Receive Configuration Reject
07:51:49, 12 Feb. (144682.320000) PPP LCP Send Configuration ACK
07:51:49, 12 Feb. (144682.310000) PPP LCP Receive Configuration Request
07:51:49, 12 Feb. (144682.310000) PPP LCP Send Configuration Request
07:51:35, 12 Feb. (144668.210000) PTM over DSL is up
07:50:55, 12 Feb. (144628.350000) PTM over DSL is down after 264 minutes uptime
07:50:55, 12 Feb. (144628.350000) PPPoE is down after 264 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
07:50:51, 12 Feb. (144623.800000) PPP LCP Send Termination Request [User request]
03:26:10, 12 Feb. (128742.910000) WAN operating mode is VDSL
03:26:10, 12 Feb. (128742.910000) Last WAN operating mode was VDSL
03:26:08, 12 Feb. (128741.360000) PPP IPCP Receive Configuration ACK
03:26:08, 12 Feb. (128741.240000) PPP IPCP Send Configuration Request
03:26:08, 12 Feb. (128741.230000) PPP IPCP Receive Configuration NAK
03:26:08, 12 Feb. (128741.230000) PPP IPCP Send Configuration ACK
03:26:08, 12 Feb. (128741.230000) PPP IPCP Receive Configuration Request
03:26:08, 12 Feb. (128741.020000) PPP IPCP Send Configuration Request
03:26:06, 12 Feb. (128739.650000) PPPoE is up -​ Down Rate=67669Kbps, Up Rate=19835Kbps; SNR Margin Down=6.0dB, Up=6.0dB
03:26:06, 12 Feb. (128739.640000) CHAP authentication successful
03:26:06, 12 Feb. (128739.600000) CHAP Receive Challenge
03:26:06, 12 Feb. (128739.600000) Starting CHAP authentication with peer
03:26:06, 12 Feb. (128739.590000) PPP LCP Receive Configuration ACK
03:26:06, 12 Feb. (128739.590000) PPP LCP Send Configuration Request
03:26:06, 12 Feb. (128739.590000) PPP LCP Receive Configuration Reject
imjolly
Message 4 of 11
more router stas than logs
if hh6 then advanced settings then technical log information
if hh5 then troubleshooting helpdesk
say-what
Message 5 of 11
ok, sorry, no worries.
Here is the log from about the same time period.
Hope this is better!?
22:35:42, 14 Feb. (370508.330000) CWMP: session completed successfully
22:35:42, 14 Feb. (370508.130000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:35:38, 14 Feb. (370504.860000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:35:38, 14 Feb. (370504.850000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
22:35:38, 14 Feb. (370504.310000) CWMP: Initializing transaction for event code 2 PERIODIC
20:21:24, 14 Feb. (362452.870000) NTP synchronization success!
16:28:54, 14 Feb. (348503.000000) SD-​100 (1)
03:12:06, 14 Feb. (300694.880000) CWMP: session completed successfully
03:12:06, 14 Feb. (300694.680000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
03:12:03, 14 Feb. (300691.720000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
03:12:03, 14 Feb. (300691.710000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
03:11:32, 14 Feb. (300661.180000) CWMP: session closed due to error: Could not resolve host
03:11:32, 14 Feb. (300661.100000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
03:11:17, 14 Feb. (300645.450000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
03:11:17, 14 Feb. (300645.440000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
03:10:46, 14 Feb. (300614.590000) CWMP: session closed due to error: Could not resolve host
03:10:45, 14 Feb. (300613.770000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
03:10:45, 14 Feb. (300613.760000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
03:10:44, 14 Feb. (300613.180000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
22:35:42, 13 Feb. (284110.710000) CWMP: session completed successfully
22:35:42, 13 Feb. (284110.510000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:35:38, 13 Feb. (284107.300000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:35:38, 13 Feb. (284107.290000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
22:35:38, 13 Feb. (284106.720000) CWMP: Initializing transaction for event code 2 PERIODIC
19:02:11, 13 Feb. (271302.300000) NTP synchronization success!
18:53:38, 13 Feb. (270789.090000) Admin login successful by 192.168.1.72 on HTTP
18:53:31, 13 Feb. (270782.830000) New GUI session from IP 192.168.1.72
18:43:30, 13 Feb. (270181.170000) New GUI session from IP 192.168.1.72
16:13:15, 13 Feb. (261166.200000) SD-​100 (1)
09:48:41, 13 Feb. (238092.110000) CWMP: session completed successfully
09:48:40, 13 Feb. (238091.920000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
09:48:32, 13 Feb. (238083.300000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
09:48:32, 13 Feb. (238083.290000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
09:47:58, 13 Feb. (238049.600000) CWMP: session closed due to error: Could not resolve host
09:47:57, 13 Feb. (238048.260000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
09:47:57, 13 Feb. (238048.250000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
09:47:26, 13 Feb. (238017.620000) CWMP: session closed due to error: Could not resolve host
09:47:26, 13 Feb. (238017.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
09:47:26, 13 Feb. (238017.220000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
09:47:25, 13 Feb. (238016.630000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
09:33:08, 13 Feb. (237159.220000) CWMP: session completed successfully
09:33:07, 13 Feb. (237159.020000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
09:32:58, 13 Feb. (237149.710000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
09:32:58, 13 Feb. (237149.700000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
09:32:23, 13 Feb. (237114.550000) CWMP: session closed due to error: Could not resolve host
09:32:23, 13 Feb. (237114.450000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
09:32:23, 13 Feb. (237114.440000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
09:31:52, 13 Feb. (237083.850000) CWMP: session closed due to error: Could not resolve host
09:31:52, 13 Feb. (237083.820000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
09:31:52, 13 Feb. (237083.800000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
09:31:52, 13 Feb. (237083.210000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
02:17:58, 13 Feb. (211049.120000) CWMP: session completed successfully
02:17:57, 13 Feb. (211048.950000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
02:17:55, 13 Feb. (211046.050000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
02:17:55, 13 Feb. (211046.040000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
02:17:24, 13 Feb. (211015.520000) CWMP: session closed due to error: Could not resolve host
02:17:07, 13 Feb. (210998.240000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
02:17:07, 13 Feb. (210998.240000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
02:16:35, 13 Feb. (210966.470000) CWMP: session closed due to error: Could not resolve host
02:16:35, 13 Feb. (210966.440000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
02:16:35, 13 Feb. (210966.430000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
02:16:34, 13 Feb. (210965.890000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
22:35:43, 12 Feb. (197714.420000) CWMP: session completed successfully
22:35:42, 12 Feb. (197713.430000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
22:35:38, 12 Feb. (197709.710000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
22:35:38, 12 Feb. (197709.710000) CWMP: Session start now. Event code(s): '2 PERIODIC,4 VALUE CHANGE'
22:35:38, 12 Feb. (197709.170000) CWMP: Initializing transaction for event code 2 PERIODIC
22:28:12, 12 Feb. (197263.280000) Admin login successful by 192.168.1.72 on HTTP
22:00:52, 12 Feb. (195623.180000) Admin login successful by 192.168.1.72 on HTTP
21:59:40, 12 Feb. (195551.650000) CWMP: session completed successfully
21:59:40, 12 Feb. (195551.480000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
21:59:38, 12 Feb. (195549.950000) New GUI session from IP 192.168.1.72
21:59:34, 12 Feb. (195545.070000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:59:34, 12 Feb. (195545.060000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:58:05, 12 Feb. (195456.070000) CWMP: session closed due to error: Could not resolve host
21:58:04, 12 Feb. (195455.180000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:58:04, 12 Feb. (195455.170000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:57:33, 12 Feb. (195424.570000) CWMP: session closed due to error: Could not resolve host
21:57:32, 12 Feb. (195423.990000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
21:57:32, 12 Feb. (195423.980000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:57:32, 12 Feb. (195423.430000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
21:56:53, 12 Feb. (195384.080000) CWMP: session completed successfully
21:56:52, 12 Feb. (195383.910000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
imjolly
Message 6 of 11
Spoiler
if hh6 then advanced settings then techincal log information not the actual logs but the hub stats under heading information
say-what
Message 7 of 11
Aaaaah, I see - Soz, been looking at event logs alot
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51942436
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 04/07/17
4. Board version:BT Hub 5A
5. DSL uptime:1 days, 03:34:10
6. Data rate:19999 / 59995
7. Maximum data rate:20809 / 69034
8. Noise margin:6.5 / 8.5
9. Line attenuation:18.3 / 17.8
10. Signal attenuation:18.1 / 17.8
11. Data sent/received:some stuff
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:Skynet
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:Skynet
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:54:64:d9:0f:19:56
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
imjolly
Message 8 of 11
did you try quiet line test?
I see you have renamed SSID but I would split the networks by adding a 5 to the 5ghz network as many devices do not like the networks combined  you could also select manually a channel rather than router on auto switching between channels
currently stable for 1+day
say-what
Message 9 of 11
Sadly not yet.
I am working from home today and will do it after I clock out.
It used to be really bad, to the point you could not hear the person on the other end.
Most of my stuff is wired. Only phones are on wifi and it cuts out for all with the orange flashing light.
Yeah, it will be ok for about a week and then go balistic for a day or two resetting all the time and then back to being ok for a few days.
Open reach guys said was the faults building up over time until it is too much for the line and then goes stupid
imjolly
Message 10 of 11
are you using the test socket especially if you have phone extension sockets in other rooms
a noisy phone line can cause drops in connection as you describe
