nirvycn
Message 1 of 5
Replacement power supply for a HH 5.0 Type B?
Anyone have any idea where i can get one.
Due to a Rabbit eating through the power lead i need a new one, and after a few hours of searching it is proving very hard to find? Is the Homehub type A power adapter a different size? Some people think it is and that one wont fit.
Cheers
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: Replacement power supply for a HH 5.0 Type B?
If the rabbit's just chewed through part of the lead, can you splice the two broken ends together to give a slightly shorter lead?  Just make sure you don't accidentally swap the positive and negative.  One of the two cores should have a distinct marking on it.
Don't assume that type A and type B poser supplies are at all compatible, without actually checking the voltages.  BT sources its hubs from different suppliers - they may look the same on the outside, but have completely different electronics inside.
nirvycn
Message 3 of 5
It has completely destroyed it, it cannot be repaired 😞
Any ideas where i can get a new one?
Message 4 of 5
Auction?
Distinguished Guru
Message 5 of 5
You could get a complete Home Hub from the well-known internet auction site.
Alternatively, check the rating carefully on the power supply, and you may be able to find a compatible one on the internet.  It will need to be the same voltage, at least the same current rating, and have a compatible connector.  There are plenty of "universal" power supplies around with adjustable voltages.
