RichardDraycott
Message 1 of 10
Replacing BT Smart Hub - but no 'DSL' light on Openreach HG612 modem.
Hi everyone
First post here after doing LOTS of reading but unable to resolve my issues!
Like many I am trying to replace the BT Smart Hub due to coverage in my house.  (Usual drill - old, thick walls etc).  I have purchased a Linksys Velop mesh system and an HG612 modem.
Where I am struggling is that the HG612 does not seem to receive a signal from the master socket.  The DSL light does not light up when I unplug the incoming cable from my BT Smart Hub into the HG612.  Between the master socket and the hub/modem there is a standard BT issued microfilter that splits the line into DSL/phone.
Any pointers gratefully received.
Thanks in advance
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: Replacing BT Smart Hub - but no 'DSL' light on Openreach HG612 modem.
@RichardDraycott
The Openreach modem will not work on Ultrafast broadband, if that is what you hav.
RichardDraycott
Message 3 of 10
Thanks Keith - I have 'Fibre 1'. Does that help?
If Fibre 1 = Ultrafast, is there an alternative modem I can use to pass a signal through to the Linksys Velop?
licquorice
Message 4 of 10
You have a faulty modem.
Keith_Beddoe
Message 5 of 10
I am not sure of the package speeds, but if you look at the connection speed of your home  hub, you should get some idea.
If it is a G.Fast connection, then you are stuck, as there are very few stand alone modems for G.fast.
RichardDraycott
Message 6 of 10
Speed to hub is about 48mb
licquorice
Message 7 of 10
See message 4
RichardDraycott
Message 8 of 10
Thank you - I'm following up with the eBay trader.
licquorice
Message 9 of 10
Is it an unlocked modem, if so the config may have been changed from default. You could try a factory reset of the modem to restore it to defaults that should be plug and play.
RichardDraycott
Message 10 of 10
Thanks again licquorice
I have tried to reset the modem by holding the reset button. Sadly, when I do this nothing happens. 😞
