Hi everyone
First post here after doing LOTS of reading but unable to resolve my issues!
Like many I am trying to replace the BT Smart Hub due to coverage in my house. (Usual drill - old, thick walls etc). I have purchased a Linksys Velop mesh system and an HG612 modem.
Where I am struggling is that the HG612 does not seem to receive a signal from the master socket. The DSL light does not light up when I unplug the incoming cable from my BT Smart Hub into the HG612. Between the master socket and the hub/modem there is a standard BT issued microfilter that splits the line into DSL/phone.
Any pointers gratefully received.
Thanks in advance
The Openreach modem will not work on Ultrafast broadband, if that is what you hav.
You have a faulty modem.
I am not sure of the package speeds, but if you look at the connection speed of your home hub, you should get some idea.
If it is a G.Fast connection, then you are stuck, as there are very few stand alone modems for G.fast.
See message 4
Is it an unlocked modem, if so the config may have been changed from default. You could try a factory reset of the modem to restore it to defaults that should be plug and play.
