Message 1 of 3
Restricting times on xbox
Hi, trying to restrict the times that my sons xbox accesses the Internet so it goes off at 23:00, typed the iP address in my searchbar so I'm in the hub but the option to restrict access is greyed out, any advice greatly appreciated
2 REPLIES 2
Message 2 of 3
Re: Restricting times on xbox
I believe the setting of restricted times is now set through the My BT App, rather than the Web UI on the Hub.
I can see it if I launch the App, then More -> Your WiFi Network -> Control WiFi access for your devices
Message 3 of 3
Great thank you much appreciated
