Neilbadmin
Newbie
Message 1 of 7
Returning a hub
Recently had an issue with broadband speed. Advisor told me they would send a new hub just in case but engineer who visited fixed the issue before new hub arrived as issue was with connection on the landline. I now have a new hub. Do i legally have to return the old hub ? Or the new one ?
Tags (1)
6 REPLIES 6
Message 2 of 7
Re: Returning a hub
If you were send a returns bag, then BT would expect you to return one of the hubs, as it will show on your records, and you may be charged for it.
Neilbadmin
Newbie
Message 3 of 7
Re: Returning a hub
Neilbadmin
Newbie
Message 4 of 7
Re: Returning a hub
There was no returns bag sent. Just the new hub
Message 5 of 7
Re: Returning a hub
Just hold onto it as a spare. The Customer Service rep said he would send one out to you "just in case" plus BT hand them out like sweeties so I doubt they will come looking for it.
Moderator
Moderator
Message 6 of 7
Re: Returning a hub
@Neilbadmin welcome to the community and thanks for posting,  it really depends on how the advisor has placed your order for the replacement Hub. If it was a replacement under warranty you would have received a returns bag to send back the old Hub for recycling so it sounds like they have simply ordered you a new Hub and not followed the warranty replacement process.
If you'd like to return the old hub for recycling I could organise a returns bag to be sent out, alternatively you could keep it as a spare. Post back and let me know?
Neilbadmin
Newbie
Message 7 of 7
Re: Returning a hub
Hi
  • Many thanks. I have ordered a returns bag to send the old hub back. Thanks for the help.
