Connecting Ring 3 to BT Hub 5 - fails - Ring device showing 2 white LEDs on the right which means not connected to internet.. Also fails the same way connecting to a NetGear wifi extender (to the BT Hub 5). Hub/router configured for split 2.4Ghz / 5Ghz, with 5Ghz wifi disabled. Also using Channel 6 for 2.4Ghz wifi. (in case its a channel problem).
Also tried with auto channel on the 2.4Ghz wifi - still same issues. Ring device refuses to connect to internet BT Hub 5 / internet.
The interesting test is that when using another connection method (cellphone hotspot) it works ok, so in doing so it shows that the Ring 3 is working ok as far as conecting to the intenet.
NOTE: Ring 3 - works ok and connects to internet if connecting to cellphone with hotspot enabled so I think its something possibly with the BT Hub 5 and the Ring 3 connection through it.
Anyone had similar issues with Ring devices and BT Hubs? and if there are any solutions?
Grateful for any help / pointers in getting a fix as I'm almost at the point of throwing out this BT 5 Junk hub for something better and that works..
Kind Regards
DeltaOskarMike
Solved! Go to Solution.
Turn off smart setup on the hub.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Hi Licquorice
Thanks for answer.. unfortunately Smart Setup already disabled (been that way for a while) as it messed up device wifi joins.
I'd be tempted to say just keep trying. I have a Ring 1 doorbell and a Smart Hub 2. It must have taken me about 20 attempts to get it connected, but since I did it has worked perfectly. Why it took that many attempts I have no idea.
Hi Northshields
I fixed it in the end.. by complete replacement of the old BT Hub 5 with a Hub 5 I got from BT (which I never got round to installing until now) - So the old Hub 5 must have been broken deep within somewhere.. I think I had an old Hub 5 Type A and this one is a Type B. - There are two variants of the Hub 5, Type A with Lantiq chipset (ECI), and Type B with Broadcom.
Hope this helps the next poor unfortunate who has problems with BT Hub's and RIng devices.
DeltaOskarMike
How do you know which BT hub 5 you have? I am having the same problem with connecting my ring 3 doorbell too
if you have the HH% whichever version have you split the 2.4/5ghz networks with different SSID? you can then connect to the 2.4ghz network
I already connected to 2.4ghz still having the same problems. Will not connect to the hub at all but has connected twice to BT wholehome momentarily then I get the same thing in the ring app every time "not connected"
Make sure Smart Setup is turned off.
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
It is turned off
