Anonymous
Not applicable
Message 31 of 57
Re: Router Upgrade from BT SmartHub 2 to a different one
Hello again @licquorice,
@licquoricewrote:
Apart from avoiding the Netgears due to lack of IPv6, they will all be suitable. Only you know what WiFi speed you need and whether it is worth paying extra for the extra speed bearing in mind unless you are using the WiFi purely within your LAN, the governing speed will be the speed of your broadband connection.
OK so basically don't bother getting the NETGEAR D7000-200UKS VDSL modem / router? What about the rest of them will any of them be any good. My WiFi speed is 66.969mbps and upload is 20mbps.
What would you highly recommended @licquorice?
Kind regards,
DanTMan64
Products with BT: BT Fibre 2 (Unlimited) with Landline
Router: BT SmartHub 2 (Will be changing to a third-party one soon)
Router sync speeds from the local Cabinet to my router:
Download - 66.969mbps
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button ‌‌‌‌.
Message 32 of 57
Recommending routers is like recommending cars. They all do the same job, any recommendation is personal preference. I would recommend a TP Link device but @TimCurtis  would recommend an Asus, both entirely suitable. You still haven't said why you want to move from using a BT hub, if you specify the features that the BT hub lacks and you require it might help narrow the choice.
Anonymous
Not applicable
Message 33 of 57
Hello again @licquorice 👋,
Thank for your speedy reply, OK I'm still undecided which one to buy 🤔
Well I am the paying customer so I should be able to change from the ISP's router, there is more settings on a third-party VDSL modem / router. I just fancy a change that's all @licquorice so if you help me decide which one I would be landed & happy 😃.
Kind regards,
DanTMan64
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button 🤗
Anonymous
Not applicable
Message 34 of 57
Hello again BT Community,
Can someone anybody please reply back to this post I need a decision ASAP, there's huge sale on and I am ready to buy one VDSL modem / router.
Kind regards,
DanTMan64
Upload - 20mbps
If you like my post or if it helped you, please thumbs up & click on Kudos button.jpg button. If your problem is solved by my post please click MaAS button.jpg button 🤗.
Message 35 of 57
You have already been given advice regarding which one will be suitable especially as your reason for doing away with the BT hub is because you "fancy a change" . It is up to you to decide which one to buy. Nobody can make that decision for you.
Anonymous
Not applicable
Message 36 of 57
Hello again @gg30340,
Yes but I don't know which to choose though mate 🤔@licquorice @TimCurtis said "Forget Netgear as they don't implement BT's version of IPv6" now I need the IPv6 & Dual-band Wireless.
Kind regards,
DanTMan64
Upload - 20mbps
Message 37 of 57
So pick one of the other four that you posted!
Anonymous
Not applicable
Message 38 of 57
But I don't know which one to choose 😫. That's why I'm asking for help before buying the wrong VDSL modem / router.
Kind regards,
DanTMan64
Message 39 of 57
None of them are "wrong". They will all work.
Anonymous
Not applicable
Message 40 of 57
Thank you! But will it work with BT's IPv6 and will the signal be perfect.
Kind regards,
DanTMan64
