NeoPhil
Message 1 of 2
Router advice
Im looking to buy a new router and I have regular BT Broardband, is this one any good and can I just plug in my little square phone line into it like the BT Hub?
At the moment I have Home Hub 1.5 but the NAT type says strict in my games and only lets me connect to very few players.
N300 Wireless DSL Modem Router DGN2200
I did buy a router the other day but it was for cable connection and the shop will not take it back now because I have opened and used it 😞
I don't want to waste another 40 quid
1 REPLY 1
Message 2 of 2
Re: Router advice
The Netgear ADSL routers are fine, there are a number of other forum members using them. Just plug it in where the home hub is connected at the moment.
You will have to enter some generic login details into the Netgear PPPoA settings.
You can use a user name of broadbanduser@btbroadband.com and a password of bt
