Message 1 of 25
Router blocking website
For over a year now I have been trying to access a particular website (nothing dodgy!) using my home wi-fi but have been unable to do so. I have tried using a MacBook and a Windows 10 laptop to no avail.
I can access it on 3G on my iPhone.
I have tried contacting BT. Last year they were unable to find any fault. Today I have spent nearly 2 hours trying to get an answer and then having got through I was cut off after 20 minutes.
I have no problems with any other websites.
Can anyone help?
24 REPLIES 24
Message 2 of 25
Re: Router blocking website
Does it happen with different browsers?
Have you turned off web protect in MYBT?
Message 3 of 25
I have tried Safari, Google and Bing. I haven’t turned off web protect but will have a look at it. Could this affect just one website?
Message 4 of 25
Yes, of course, that's it's purpose.
What is the URL you are unable to reach?
Message 5 of 25
But why only one website?
Message 6 of 25
It's not just blocking 1 website, it's blocking websites that it considers you should be protected from. It just happens that you are only trying to access 1 of the thousands of sites it protects you from.
Message 7 of 25
Turned it off. No different. Still won't let it load.
Message 8 of 25
What is the URL?
Message 9 of 25
Message 10 of 25
No problem accessing it here. Make sure you have no parental controls enabled.
Try changing DNS servers to 8.8.8.8 and 4.4.4.4 on your laptop/MAC
