Message 1 of 4
Router with guest network feature
My friend is looking for a router with one that has guest network for his small cafe and has a budget of around £40 and I have narrowed it down to the TD-W9970 or Business Hub 5/Smart Hub, which one would you say is better?
3 REPLIES 3
Message 2 of 4
Re: Router with guest network feature
Only the TD-W9970 has a guest network which can be configured by the owner.
Distinguished Guru
Message 3 of 4
I use the W9970 and it beats the home hub hands down. Not once have I had to re-boot it like I had to with the HH to solve all it's problems.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Expert
Message 4 of 4
The TP-Link VR400 has a guest network and may be around the same price.
