Kais_1
Message 1 of 4
SG-1100 PFSENSE
SG-1100 PFSENSE® SECURITY GATEWAY APPLIANCE
will this device work with my btsetup?
3 REPLIES 3
licquorice
Message 2 of 4
Re: SG-1100 PFSENSE
That's just a firewall.
Nobby99
Message 3 of 4
Re: SG-1100 PFSENSE
Yes you can use the pfsense as PART of your connections to BT. You will still need a Modem to connect to BT.
So it would look like
BT Faceplate  >>>>> Your Modem >>>>>>> Pfsense >>>>>>> You local network.
Remember that the Modem has to connect to the BTcircuit ( I have used the Netgear DM200 before)
The modem will "speak" PPPoE to BT and conventionally  it will have an ethernet port to connect to the Pfsense.
Regards
S
Kais_1
Message 4 of 4
Re: SG-1100 PFSENSE
what about the draytech vigor 130 modem
will that work with bt infinity
