WARKSTER
Message 1 of 5
SKY Q
My FTTP has gone live today, I have switched off the  smart setup on the BT SH2.
I have switched the sh2 5gz to c44 and switched of 2.4ghz in all the sky q boxes.
is this what I should have done or anyone got the Optimum settings between the two?
i find it all very confusing!!
4 REPLIES 4
VeteranISPUser
Recognised Expert
Message 2 of 5
Re: SKY Q
Hi @WARKSTER   If you have switched off 2.4 GHz on the Sky Q Main box then you will have a problem because Sky Q only uses the 2.4 GHz band to connect to non-Sky routers. If you are still having trouble then try Wireless Mode 2 on the SH2.
imjolly
Message 3 of 5
Re: SKY Q
the SKY Q will probably connect on the 2.4ghz network so I would have that enabled.  My 2TB box and 3 minis connect to hub on 2.4ghz
WARKSTER
Message 4 of 5
Re: SKY Q
Ahh in have connected the main q box via Ethernet.
i thought the minis connected is 5ghz??
WARKSTER
Message 5 of 5
Re: SKY Q
I’m not convinced this is right getting 150mbps then drops to 10 deffo something to do with sky q draining it!!
