Message 1 of 3
SKY to BT Infinity Cabling
Hello Folks,
Looking at making the switch, can someone please tell me how the cabling differs? My SKY install is approx 5 years old and is all nice and neat, runs from the pole to my house down to an airbrick under the floor and straight up to a cabinet where all the plugs are, the existing router is sat on the top of said cabinet and i dont see any cables and want to keep it that way.
Does the Infinity install require any change of cabling?
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: SKY to BT Infinity Cabling
Its exactly the same.
Distinguished Guru
Message 3 of 3
BT would just use the existing cable from the pole as well as the socket located in your premises, the switch from sky to BT will be done in the local telephone exchange.
I expect there would not even be a need to visit your premises.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
