Karl_Epps
Message 1 of 3
SMART HUB 2 disable SSID Broadcast
Hi,
I have just received and set up my new Smart Hub 2 and disc which was much easier than previous devices. Does anyone know how to disable the SSID Broadcast for this model as the setting appears to have been removed.
2 REPLIES 2
albertj
Recognised Expert
Message 2 of 3
Re: SMART HUB 2 disable SSID Broadcast
Hi @Karl_Epps
Welcome to the Community!
Unfortunately, this is not possible with the BT Smart Hub 2.
There is little point anyway because if you could then the BT-WiFi would still be visible, it also wouldn't prevent hacking if that is a concern. If someone can crack the password I am sure they could find the SSID.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Karl_Epps
Message 3 of 3
Thanks @albertj ,
At least I can stop looking for it now. This seems like a very capable device and I'm looking forward to seeing how stable it is - my previous HH6 was the most stable that I have experienced over the years.
